Shows how the nodes are configured in a stack topology. The configured values shown are the ones actually stored in the remote nodes at the time you issue this command.
N/A.
Some stacking parameters do not take effect until the next restart, the configured values and the values currently being used are both shown. Specifically, this applies to the slot number, whether or not stacking is enabled, the master-capable configuration, the license level restriction, and the stack MAC configuration.
The only parameters that take effect without a reboot are the node priority and the alternate management IP subnetwork and gateway.
Identified with the asterisk, the current node is the one on which the show stacking configuration command is executed.
A row that displays the ? indicator shows the last values that were received from the node. If no values were ever received, all configured values show as not configured (-) or none. The node MAC address and the slot number that is currently in use are still displayed.
The following example shows the stacking configuration for a switch:
Slot-1 Stack.2 # show stacking configuration Stack MAC in use: 02:04:96:26:6b:ed Node Slot Alternate Alternate MAC Address Cfg Cur Prio Mgmt IP / Mask Gateway Flags Lic ------------------ --- --- ---- ------------------ --------------- --------- --- *00:04:96:26:6b:ed 1 1 Auto <none> <none> CcEeMm--- -- 00:04:96:34:d0:b8 2 2 Auto <none> <none> CcEeMm--- -- * - Indicates this node Flags: (C) master-Capable in use, (c) master-capable is configured, (E) Stacking is currently Enabled, (e) Stacking is configured Enabled, (M) Stack MAC in use, (m) Stack MACs configured and in use are the same, (N) Stack link protocol Enhanced in use, (n) Stack link protocol Enhanced configured, (i) Stack MACs configured and in use are not the same or unknown, (-) Not in use or not configured License level restrictions: (C) Core, (A) Advanced edge, or (E) Edge in use, (c) Core, (a) Advanced edge, or (e) Edge configured, (-) Not in use or not configured
Stack MAC in use: 02:04:96:f1:b8:00
*00:04:96:f1:b8:00 1 - Auto <none> <none> -c----iNn -b
(N) Enhanced protocol is in use, (n) Enhanced protocol is configured,
License level restrictions: (B) Base, or (P) Premier in use,
(b) Base, or (p) Premier configured,
This command was first available in ExtremeXOS 12.0.
Licensing information specific to ExtremeSwitching 5520 series switches was added in ExtremeXOS 31.1.
This command is available with all licenses and platforms that support the SummitStack feature. For information about which licenses and platforms support the SummitStack feature, see the Switch Engine v33.1.1 Licensing Guide document.
